Results 11 to 20 of 27
Thread: Best Cam For 4.8??
  1. #11
    Pittsburgh, PA
    ok. What I meant was if you have 2 cams.
    1= 226/336 .625/.625 110lsa
    2= 226/236 .525/.525 110lsa
    The second cam is going to be easier on the valvetrain.
    Anyways, figure out what sound you want, and what goals you have. IMO the ASA cam was a nice cam. cost effective horsepower. And could run just as long as a stock setup. If you going to DD it, I would suggest a lazy lobe, and lower lift. If its a track truck, and your not going to put 12kplus miles on it, go more aggresive.
    well that also goes back to what lobes its on. you can have 2 cams with similar specs but totally different lobes.
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
  2. #12
    ff_jeff Guest
    OK funny guy. the 2 cams I mentioned are identical, minus the lift.
  3. #13
    Yup. Like Comp's XER, XFI, and XE. They all could be the same lift...but the lobe design counts too!
    And that's why I got the XERs!!
  4. #14
    Pittsburgh, PA
    you can also have mixed lobes. the more aggressive the lobe the less life of springs.
    412 Motorsports
  5. #15
    ff_jeff Guest
    Your killing me smalls.
  6. #16
    It's "You're." Not "your."
    Great movie, BTW.
  7. #17
    san antonio, tx
    which of comp's lobes are the "laziest" or easiest on valve springs?
    2008 Black RCSB Sierra 4.8L
    14.78 @ 90.93 mph
    My Garage
  8. #18
    A .000"/.000" 000 @ .050" with a 0 LSA is easiest on the valve springs.
    Jeff, there are rainbows in your sig pic.
  9. #19
    Im Gonna Do The 224 On A 112,THAT SHOULD BE GOOD FOR A 6.0 LATER
  10. #20
    wow lmfao i said that^^ on my birthday and ended up getting the sucky thumper cam,now im back in this situation got rid of the thumper and hate the syock cam!! lol
    so now its between these 3
    216/220 trick flow
    tr 220
    tr224
    what ya think
