Critique my motor assembly- Need help
Ok, I'm looking for any advice that can be given to me about my upcoming build.
I have:
-2002 escalade LQ9 6.0L w/ burned intake/drivers coilpacks
-GMPP Hot cam and LS6 valve springs
-F body oil pan/windage ect
-2007 TBSS LS2 Intake w/Flex fuel Injectors and rails
My understanding is that all these parts should work well together. Any guesses to tq and hp numbers?
I need new coilpacks. Are there any applications that are the most desirable?
Stock LS2 injectors are around 32lb correct? What about the flex fuel LS2? Will they work? I've talked to a few harness builders and they all say its no problem.
What 90mm TB would you guys recommend? Right now I'm leaning towards the Nick Williams TB
Thanks in advance. Any advice or tips is appreciated before I tear into this thing.
- You may not post replies
- You may not edit your posts
