do I need the tbss injectors and rails? Do they do me any good? Or should I stick with my stock ones?
06' Silverado RCSB 5.3L 4wd..
HID's Hi, Lows & Fogs
Get them if they're available to you, makes for a cleaner install. I'm not 100% sure they're the same connector though, injector connector.
Oh shut..! Does anyone know if they have the same conector? Thanks man!
Connectors are different If you can get the fuel rails with it--do it. Cause if not, you have to get longer bolts if you reuse your existing fuel rails.
so, if they are different, what can I do to make them fit?
Thanks
You will need longer bolts and some bigger diameter washers.
