Results 11 to 20 of 38
Thread: Dyno day Sat 1/10/09
    Dec 2003
    Azle,TX
    Ill be there after 12 myself...Ill talk to Ross when i get there and Im sure they will still be there...PM me your cell number so i can call ya if times change.
    Vortec Performance Tuned
    wichita falls, tx
    saved...u can delete your num if you would like
    ill call you before i leave here....thanks!
    Intro Radicalli's
    I need the secret on running 2WD as it didn't work out well last time I tried. I'd like to be there this time AND get a run.
    Ft worth tx
    Im going to try and make it that day.
    2004 Gmc VHO (LQ9), AEM cai, perma cool e-fans, aero turbine 3535,obx lt's,undedrive pulley w/overdrive alt pulley, lingenfelter 160 t-stat, zippy tune, taylor 10.4mm wires, tb bypass, Transgo HD-2 c, corvette servos, sonnax accumulator piston's,2600 stall,30,000 trans cooler lowered 1.5"/2", boss 313 22's on 285/45's, rollpan,shaved tailgate w/ss spoiler, painted interior, 2 solo l7 12's,custom fiberglass box,Pioneer F-900 Navi,SSS gauges,billet shiter and pedals,hid's (low's and fogs).
    Oct 2007
    weatherford,TX
    wont make this one got invited on a cruise, plus truck is running like s***t anyways
    [SIGPIC]5.3 k&n cai ,asm lt, hf cats, aero turbine muffler, vhp 216/224-551/551-115lsa, tbss intake, ls2 90mm tb,tb bypass, comp double roller tc, hv oil pump, ls2 injectors,nelson tune, b&m super cooler, taylor 10.4mm wires, ngk tr55ix, 373 Detroit tru trac,
    midlothian, Texas
    got a question, do you guys with larger verters just run it unlocked in 3rd or 2nd or use efi or hptuners to lock it up or what?
    06' rcsb silverado H/C/I/N2O 5.3
    wichita falls, tx
    hpt to lock it
    Intro Radicalli's
    Who from here is going? ANY advice on making my AWD work this time? If not, I'll drive the POS and see if I can break 100 RWHP.
    What was Can's number when she ran the Danger Ranger? Hope I beat that...
    Dales going to be there about 11:30. I may make an appearance, too.
    OK....getting started. Guess I'll have to be 2 cylinders short.
