Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: 99-02 Caltrax
    Did the sale go through?
    Daily beater: 1997 Ford Escort
    WIP: 96 S10 - 408 stroker: LQ9/T56 Swap, Callies Compstar Rods/Crank, JE LSx FSR Pistons, L92 heads w/.660 spring upgrade, Synergy custom Cam, 90mm Nick Williams TB, Yella Terra 1.7 rockers, Sanderson's LSx conversion headers, Compcams Magnum pushrods, Strange Prostreet 3.73 gears, Corvette C-5 brake conversion front, Firebird Trans-am conversion back, 03 Cobra injectors, Nelson tuned CPU/Wideband,
    casey23 Guest
    sale
    Quote Originally Posted by Elzz49 View Post
    Sorry man.. its pretty much a done deal... i think a new set is 330.00 ..... the biggest hastle is getting the old leaf spring bushing out.....
    Feb 2008
    Quote Originally Posted by casey23 View Post
    The lower brackets for a Flip kit are Flat because the axle is on top of the spring.... it sits flat under the Lead spring and U bolts Clamp the axle down.... My truck isnt Flipped to so axle is on the bottom.... The Brackets have to Fit completely around the Axle tube and Flat U bolts hold the spring Plate down on the Axle so it does not move around...... Hope this Helps
    ahh okay got it...thanks man good luck with the sale!
    04 RCSB- 4.8- bolt-ons..nuff said
    carbs are for salads and lawnmowers,
    Ah no worries, just checking in case it didn't thanks!!
