Results 11 to 20 of 36
Thread: lt1 or ls1
  1. #11
    Quote Originally Posted by zeake View Post
    Hey who took over Davids account. He has never owned an LT1.
    Least I don't think he has.
    Trust me. I have owned a SOLID iron block that is slower then grandfather time. It was an 83 ford.
    Hope Mills, NC
    I had an lt1 in my 1988. it was a 383 stroker and it was a pain in the ass. never got it right before it took a dump on me. NEVER AGAIN! Curse the lt1 and its pitiful optispark and old school design. Go LS much more bang for the buck. Plus, you can make 700hsp on a stock bottom end on an LS. Dont even think of trying that with the pitiful LT. Iv done it, dont waste your time! oh yea, anyone wanna buy lt1 parts? lol
    2005 GMC RST *sold
    2006 Silverado SS with nawz
  3. #13
    ls1!!!
  4. #14
    Bakersville, NC
    you can use a Dist on a LT1 and ditch the optispark or you can convert over to using coil on cylinder like the LS motors use
    as for ease of swap. the LT1 will be much easier as its the same as a vortec motor aka SBC that came stock in those trucks.
    to use a Dist you need to find an intake with provsion which is possible if you go with a carb or get an EFI intake that is stock and have someone drill a hole for the dist and build up the base with some weld. ive seen it done on a 9s F1R blazer.
    as for power cant touch the LS motors but it comes down to your budget really and knowledge
    This is a must, you'll have a lot less problems heres the intake you need.
    GM Part # 24502592 LT1 4-bbl Intake
    [IMG][/IMG]
    David,
    2003 GMC Sierra Denali, LQ4, AWD, AWS, 4.10, Wheatley 93 tune, LT headers, GMPP CAI, BBK 80mm TB, MSD wires, E3 plugs, 160* T-stat, Flowmonster DI/DO, cutouts. Working on 4.8 heads, just purchased Comp 228R cam, 918 Springs, TI retainers, 7.4 hardend pushrods,
  5. #15
    Hope Mills, NC
    if he uses the lt1 accessory brackets it is trick. for any impala, camaro, trans am, or firebird lt1, you will have to get a different set of accesory brackets from say street and performance, or notch the frame. you can use corvette accesories as they mount everything up top. either way its alot of cutting or alot of money for brackets!
    2005 GMC RST *sold
  6. #16
    Jan 2007
    bothell wa
    Quote Originally Posted by turbo4.8 View Post
    i have an LT1 in my 1990 2wd using stock camaro accessories and no notching was needed, (im not really sure if you meant he couldnt use them or not) yet again, im not running A/C either.........ahh im not really sure now?
    2000 rcsb z71. Bought it from my dad, the original owner! 100k on the clock. corvette servo. soon to be tuned!!
    1990 2wd rcsb. stepside. lowered 2 and 4. cowl hood. molded roll pan. 89 BMW recaro leather seats, dakota digital guage cluster. LT1 swap: ported and polished 96 corvette heads, LT4 hotcam kit, pcmforless tune, nv3500 5speed, corporate 14 bolt rear with spool and 4:11 gearing.
  7. #17
    Use LT1 Corvette brackets and no notching is needed but you're still using 14 year old technology and a crappy ignition system. I ran one for about 8 years. Loved the power until I had to buy my first $400 optispark unit and $200 water pump.
  8. #18
    Jan 2007
    bothell wa
    it takes a certain type of person to want to fight the lt1 but when they run good, they run GOOD!
  9. #19
    No crap, Greg. My only problem with this post of yours is how cheap you bought those parts. GM wants in excess of $500 for the Opti-crap and more than $300 for the pump....plus all the other stuff that's needed to make an over-glorified 267 run. Anyone familiar with the LT1 (not the LT-1 that is a different 350 all together) also knows that finicky jumper harness between the engine harness and the Opti-bark is $200 and IS ONLY 4-6 WIRES....!!!!
    :bsflag:
  10. #20
    Even NAPA prices are better than GM.
