New Tranny?
I figured i might get a more reasonable response here other than "That sucks, good luck."
I was driving and noticed a bunch of smoke. I was close to home so i checked it when i parked. I saw the servo hangin out so i took it to a near by shop so they can put it in and be done with it. Upon further inspection, they found that part of the housing that holds the servo is broken and the servo will not go back in. Shop said i will need a new housing. What should i do? The shop said they are gonna try to find me the best deals they can on used, remans, new and i asked them to check for 80Es and 65Es. Need advice please. Limited in the amount of money i can spend. Thanks.
Chris
- You may not post replies
- You may not edit your posts
