Cam question
Ok, i have been doing some research about cams but still need some help, i have read a ton of threads on here and pt.net. trying to find a decent cam to put in the truck. Now i'm not trying to just stuff the biggest cam in the truck i can as i have seen a lot of people ask about or huge gains anywhere. I am looking for something a little better then the stock cam though with a little bit of a lope to it. So i have been on a couple different sites looking and here are some i am thinking about, but i need a little help also, here are some that i think will work for me so far, thanks in advance:
Cranecams: 1449041
GOOD DAILY DRIVER, STOCK TO SLIGHTLY MODIFIED 4.8L THRU 6.0L, GOOD FUEL ECONOMY, LIGHT CHOPPY IDLE, LIKES HIGHER ROCKER RATIO, NEEDS NO TUNING - RPM RANGE 1800-6000. 551 / 551 210 / 218 114*
http://www.cranecams.com/newproducts...8B/PP0808B.pdf
or
GM Performance 12480033 - GM Performance Parts Gen 3 Hot Cam Kits - summitracing.com
or but can't find the specs on this one
COMP Cams: Thumpr™, 275THR7 <br>High Performance Street, Stock, Choppy/Thumping Idle
- You may not post replies
- You may not edit your posts
