Results 11 to 20 of 22
Thread: harness
  1. #11
    so should i be searching for another harness, and ecm if i want to run a old 4l60e. Would an ls1 with a 4l60e harness/ ecm work?
    the ecm i have is for a 4x4, guessing 4l80
    93 ECSB...lq4 6.0 swap, 255 walbro,cai, ported tb, shorty headers, 3" exhaust, tune,electric fans, NX wet kit 100 shot, 2/4 drop, beltech shocks, boss 335 22's, 295/30/22...looking for a cam.
  2. #12
    wichita falls, tx
    see how many wire go in the trans plug, then let me know and ill see how many are on mine, if its for an 80e i believe it has 2 less wires
    Intro Radicalli's
  3. #13
    there are 19 total wires in that bundle. Dont know how many of those are for the trans. Im guessing 5 for the MAF, then that leaves 14 wires.
    how many wires do the 02 sensors use, are they 3 wire sensors???
    and is there an extension for the rear 02's or are they still part of the whole harness?
    thanks for the help
  4. #14
    wichita falls, tx
    o2 sensors have 4 wires i believe on these trucks
    Intro Radicalli's
  5. #15
    The fbody/ls1 harness will be a lot of work to use on a truck setup.
  6. #16
    why's that? wouldn't it be the same, actually easier to wire in electric fans...You have more experience, so i would trust your opinion better...just curious.
  7. #17
    gotta change out the injectors or connectors to work with the LS1 harness for the start. 99 to 2002 fbody harnesses are what I am familiar with the most. You may have to extend the MAP sensor wire, also. You are using truck accessories and intake?
  8. #18
    I am using the stock intake manifold and accessories, I can solder the old connectors from the 6.0 harness to an ls1 harness.
    Are there any other connectors that are different other than injectors.
    I have a pcm, serv # is 12586242, am i able to use this since my 6.0 is cable and not fly
  9. #19
    MAP most likely, maybe have to change out the alt connector. I'm installing a LS1 style aftermarket harness to a 5.3L right now and its all going good but I'm not too sure what a factory harness would consist of change-wise to work on the truck engine. The PCM should work but if you're getting a tune anyway, trade up for a 411 PCM. The Fbody PCM program has the benefit of being able control both fans independantly with multiple speeds.
  10. #20
    cool, i know i keep asking this question but, will that pcm or one that ran a 4l60e in a fbody run my old 4l60e???
    Are those the last numbers on the pcm,411?
