Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: Maggies??
    I Got The 112 On My 4.8 And It Suprised Me
    Feb 2008
    Arizona
    how much power do you think I will be getting out of that setup that you just mentioned?
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    MidnightRider Guest
    its fully capable of 500+ rwhp if donr properly tyler and danny were there for my install and have been a huge help with getting the blower right i have spared no expense and have a fast reliable setup i also get 20-22 mpg out of boost highway
    Quote Originally Posted by Felix Arrizon View Post
    Well, like it is mentioned below, with the supporting mods, you can achieve over 500+ hp. But you will need a smaller pulley, a meth kit, cam, valvetrain, properly sized injectors, etc. It isn't a horrible idea if you had your stock heads cleaned up and had a 5-angle valve job done. When you spec your cam, make sure it is slightly intake biased--(for a 5.3L) something like a 220/218 .581/.563 115 LSA. I am by no means a cam spec pro, but something in that range is what I would spec for my own truck.
    Quote Originally Posted by MidnightRider View Post
    Yeah, Jason's truck is very reliable and with his 3.42 gears, he does get decent mpgs on the highway...
    Nov 2005
    San Jose CA.
    if i am wrong I will chock it up to old age but I am pretty sure the TVS (Gen VI) is 4 lobe and the gen V (112/122) is only 3 lobe but I will check with Magnuson in the morning for ya.
    626/762 2005 SIERRA 11.34@119.81
    My other ride is a '91 Electraglide custom.
    Feb 2008
    Arizona
    WTF? Im confused...
    Nov 2005
    San Jose CA.
    WTF? Im confused...
    about the lobes? A supercharger is nothing more than an air compressor, shoving air into your manifold/cylinders. A 112 compressor is good for an engine up to and including 6.0, anything larger should go with the 122 or a Gen VI TVS unit of which there are 2, the 1900 and 2300.
    I have a 112 and do just fine with it, probably pushing it just past it's peak efficiency range but it works to push my 5300lb truck into the mid 11's.
    May 2004
    Frederick, MD
    If anything he is helping your sell. Why buy a 122 for more money when he can buy your 112 (polished) and get pretty much the same boost out of it. I was personally involved in taking a 112 off and putting a 122 on and that truck (6.0L) didn't gain any boost. Yeah yeah, he changed cams, but unless you can get a 122 for the same price or cheaper...I'd just do a 112. You can almost get a better deal on a 112. Just my 4cents. (inflation and trying to cover my losses in the market)
    2K Silverado 4WD/6.0/80E/TVS1900/Juiced at the track
    Tuned by the Seat of My Pants
    12.22 @ 110.75 blower/meth/110 (76*) (radix)
    12.130 @ 109.95 blower (45*) (TVS1900)
    11.66 @ 115.95 bower/meth/110/50shot (45*) (radix)
    11.35 @ 117.35 blower/meth/110/75shot (45*) (radix)
    May 2004
    Trever1t is correct, they are both high helix but the MP122 is 3 lobe 60 degree and the TVS is 4 lobe. They didn't go 4 lobe until the TVS.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
