i have found out something...........no performance mod is cheap lol
00 silverado
www.quickstreettrucks.com
00 silverado
i personally think you can do it, get with allen, on the budget build, a cam 220/220 or 224, headers, and heads, you can find the cam rather cheap through out the web ( other sites ) heads, i got a set for ya , assembled even a cam, you can get this for less 1500.00 headers would be the only thing you'll need new.. unless you get lucky and find a set on the net.. but you'll have to do the work forself to make this a budget.. i personally domt think it would take much to get a RCSB in the 13s now how low would be another story....
Simple: 408 on steroids!
single digits coming soon!
I'm running K&N FIPK, Pacesetter LT's, Offroad Y-pipe, flowmaster system with a series 40 muffler, Crane Cam's 212/218, 918 springs and a 4.56 rear gear running on 31.5" diameter tires with a local guys tune, stock tranny and stock stall. If you had a stock diameter drag slick, you could put this set-up in the 13's in the 1/4 mile and 8's in the 1/8th.
Eric "The" Pyles
14.06 @ 96mph / 9.02 @ 79mph
302 RWHP/298 RWTQ
Yeah, everyone is right on track with the mods needed. But a 13 sec truck like yours is going to need a better tranny than the NV3500 that is in it now. Some people say that it can handle the power...but then again people say that about a 4L60e. I would try and to a T-56 swap into it as soon as you can.
I'd say 13's would be fairly easily done for $1500 with a RC stick...
TSP has the Pacesetter headers for $269
Dual Exhaust $250 (around here)
TSP Torquer v.2 or v.3 cam kit $600 (springs and rods come with it)
Move your MAF to right in front of the intake and add a cone filter straight out front.
I'm so tight that my small list of mods seemed really expensive. Maybe it was because I did it all at once?
