wow.![]()
wow.![]()
very nice! We have close to the same mods
●01 silverado x-cab w/5.3 ● STS GT-67 ball bearing turbo kit(relocated under cab)● Comp 918's ● Comp Hardened Pushrods ● Comp Cam 212/216 .557/.561 114 lsa● 42lb injectors●Walbro 255lph inline●OBX Intercooler● YANK 2600● Nelson SD Tune● Magnecore 8.5mm wires● STS meth Injection●Comp valvesprings● 05' e-fans w/ 34" radiator● ARP rod bolts and headbolts● NGK TR6 plugs● Eaton Posi● DB Rods bagged 4 link● FLT lvl5 4l65e● Apexi AVC-R boost controller ● z06 6 piston brakes front/4 piston rear 14" rotors ● Goodrich SS brake lines● powdercoated frame
nice numbers![]()
'13 silverado LT...stock
'11 lt 4x4 z71..tvs1900
Damn Jay--that is badass that you gained 100rwhp by those mods! your truck sounds badass coming off boost!
Ya, I was pretty happy with the numbers but Allen said my turbo is close to maxing out and I could probably gain a little more by upgrading to a bigger one. It definitely feels alot stronger!!
linky no worky any more i wanna see!
2002 Chevy Silverado LT 5.3L z71 ECSB, Fully Built DMC 4L65e, Transgo 4L65E .500 Boost Valve, Transgo Shift Kit, Billet 1st Gear Servo, 2nd Gear Sonax Super Hold Servo, 4th Gear Billet Servo, Rebuilt 10 Bolt w/ OEM G80 and 3:73's, Dumped Single 3" Spintech Muffler, 3" E-Cut Out
Damm Nice Numbers!!
