Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: Auto-on Headlight fuse?
    Worked, Thanks. Finally no more DRL.
    Maui, HI
    I replaced the light resistor on my 99 with a blue LED, cant remember the voltage but it looks good and now I can enjoy using the switch.
    99 Silverado 1500 4x4 RC 4.8
    4L60E, 3.73, Homemade CAI, 92oct Quik tuned,
    08 Tahoe radiator/fans, Dumped exhaust... summed up one loud pig caller |[226K! on odometer|
    Would any of you guys happen to know how to check the wiring of the ambient light sensor on a 2000 Silvy for shorts?
    I have a DTC telling me theres a short having to do with that sucker. So how do I get to it?
    How were you able to read a body code?
    The top of the IP has to come off to get to the sensor. This requires removal of the cluster bezel, a-pillar moldings, RH HVAC outlets, IP end caps, and the grab bar. There are two Phillips screws on each end and one behind each RH vent removed. There are about four 7mm bolts on the RH side.
    Oct 2008
    Asheville,NC
    On the 98-99 OBS trucks you can pull the DRL fuse and if you don't have fog light everything will be fine.
    98 Silverado z71 5.7 Vortec
    The Citadel
    Class of 2009
    Echo Freak Show
    As long as you don't need brights.
    Buffalo or Rochester, New York
    I know this is a really old post but is putting in a blue LED the only way to bypass the auto light feature on 99 GMT800's? I would like to have it like a 2001 where you hit the dome override a couple times. And it sounds like a serious pain in the but to get to that sensor to change it too
    Kyle - 2004 K1500 Z71 RCSB 5.3
    - Nelson 93 Octane Tune - LPP Long Tubes + Y - Gibson Extreme Duals - Cut Up Stock Air Box - 10.95 @ 67 in the 1/8 -
    - '05 Pickup Front Brakes - '05 Suburban Rear Brakes - Russel Stainless Braided Hoses -
    - DTRL's Turned to Park Lights - 4-HI Mod - '05 SS Seats -
    - I downshift near hybrids so they can hear me hurting the environment. -
    Maui, HI
    I just removed the radio and reached back for the plug, this takes about 10 minutes or 20 if your on the slow route lol.
    hot & windy
    i tried just reaching behind the radio, but 1: i have big hands, so they didn't fit all the way back. 2: the sensor housing was warped & catching on something so i couldn't turn it from the top either. my only choice was pulling the dash. that took a whole 20 minutes, not knowing what the world i was doing, 10 minutes the second time. just unplug the light sensor & put a 1.5kOhm, 1/2W resistor in the socket & tape it together real good. that will eliminate the auto-headlight system. the DRLs will run all the time (even with parking lights) until you turn on the headlights.
    00 FRC - just top end, exhaust, and a hot-air intake
    99 Sierra - 5.3 / 5spd
    ↓ click the pic for the build ↓
