NAPA is your friend...... They have pretty good prices on the AC Delco parts.
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
2004 Tahoe LT
2006 Silverado Z71 LS
1971 Chevy C10
I checked with my local napa and the only store pretty much on my side of the island now for about 28 miles (which it takes 45min-1hr sometimes to get to the other side of our island), it was $158 for a oem replacement vs dealership wanting $400... good price?![]()
99 Silverado 1500 4x4 RC 4.8
4L60E, 3.73, Homemade CAI, 92oct Quik tuned,08 Tahoe radiator/fans, Dumped exhaust... summed up one loud pig caller |[226K! on odometer|
Told you the OEM was high.
Milky oil means you have a leak, and coolant is getting mixed with oil. If your plug was covered in oil that's not good.
yah didnt think that the plug covered in oil was good.
well couldnt find any traces of a leak anywere I was under the truck looking for trails and I took some parts of to have more room to look on top and nothing truck isnt overheating either at least my the guage reading
Let's see... no foam in the oil, no stains on the driveway, passenger side carpet is dry, no coolant leaking out of the weep hole in the water pump behind the water pump pulley, water bottle isn't showing signs of fluid leaking... what color fluid is in the truck? Can you add a flourescent dye to the radiator fluid and trace it with a black light? Check the seams of the radiator where the end caps are crimped over the plastic ends for leaks. Worst case scenario you have a head gasket leaking or bad water pump. Get lucky and its just a bad hose, corroded crossover airbleed tube or gasket or a leaking radiator tank cap causing it to steam the water out.
Have you tried putting a coolant pressure tester on it? It would help you to locate the leak cause it will pressurize the system.
Are you sure it is eating fluid? On a cold start up on a warm morning, look for a little smoke coming from the tailpipe. I know this sounds weird, but smell your exhaust...if it smells kinda sweet, then there is a leak in the block/heads somewhere...
It could be leaking and not drinking coolant ill do a pressure test this week. And when i start my truck it smells like a motorcycle kinda like a harley
