For all you 4x4 guys
Not sure if this has been brought up before but I will anyways. I am doing my 5.3 and 4l60e swap and I found out that if you still want to use a manual transfer case you can use an eighties np208 transfer case. The spline counts are the same and so is the bolt pattern so it mounts up perfectly. Just thought I could see if I could help someone out.Travis
- You may not post replies
- You may not edit your posts
