i smell oil!
ok i have breathers on my pvc and valve cover cause when i get into boost hard i was getting oil in my intale ,hence fouled plugs smoke etc.the problem im having is that whenever i come to a stop i get alittle condensation smoke and i smell oil ,its definately coming out of the breathers i can watch the vapors come out of the breathers.does anyone have this issue and how can solve it?
