Alright guys im literally dead center in the middle of lower my truck ive got it all up on jack stand all wheels taken off. Im trying to drop the front first then drop the back.
Ive disconnected the tie rods, and removed the stablizer link bars. Ive also loosened the the lower and upper ball joint nuts but there not off. Also my front shocks are out too. And the lower control arm is supported my a jack.
Now my problem is i cant remove the lower ball joint to save my life.... when you guys says spindle do you mean the steering knuckle? Im just using a haynes manual and they dont use the word spindle in it at all.
I dont have a sledge hammer but i do have a 15lbs caprock breaker bar which should be good enough... What the hell am i doing wrong? Thanks
Brandon
