Results 11 to 20 of 26
Thread: ready to knock off 11's N/A in my ECSB
    Jan 2005
    Humble/Houston TX
    what am i guna have to do to get the truck injectors to work?
    what kind of water pump do i need? i know ive read this stuff before but i never actually thought i would be doing the swap...i was a big non-beleaver of the ls6 intake but im hoping my larger cubes and heads will make them a benifit.
    old mod list: H/C/I/N/E/G 408
    will probably have to buy some fbody billet fuel rails such as those from professional products. post up in the parts wanted section, I think Ramsey has some he'd like to sell but make sure he sells you the complete kit will all fittings.
    Yes Greg, I was intending to mean the Corvette FRC. Someone had them (maybe you) and they looked pretty sweet...
    May 2006
    Waco TX
    Sweet Stew. I cant wait to see the times!!!
    Quik had them on his old setup. I also had them on my LS1 intake. Now they're in a corner, won't fit any more due to LS2 fuel rail configuration.
    Jan 2005
    Humble/Houston TX
    will converting to ls1 accessories work with my underdrive pulley? any ac issues? im trying to figure out a way around all of this and make it look good.
    I am sure it will be fine. You will just have to get a belt to fit all of it. Once the accessories are on, get a string and wrap it around all of the pullies to get an overall length of the belt. Then go up to Vatozone or wherever and match your string length to the correct belt size.
    There will be an alignment issue using LS1 accessories with a truck crank pulley.
    Greg, I thought the LS1 water pump has a very wide pulley so belt alignment won't be much of an issue... Please advise, oh Holy One...
    the water pump wont be the issue, its the idler, power steering and alternator pulleys that won't be in alignment with the grooves in the truck pulley. They can be spaced out with longer bolts and spacers but it would be much better to just get an fbody crank pulley rather than rig it up like that. Of course the fbody pulley will render the A/C alignment worthless.
