Results 11 to 20 of 36
Thread: Anyone else go through oil?
  1. #11
    Jan 2007
    Burleson,TX
    I havent lost any oil...doesn't drip anywhere either...course its only got 35K miles on it...Hope you figure it out Moze
    06 silverado CC Volant CAI/ Corsa Sport exhaust
    dynatech supermaxx headers/cats
    LPE GT2-3 cam/ Comp 918's/ Rods
    Eaton LSD 3.73's
    IAT Shocks
    DANNY TRANNY w/2800 TCS billet verter
    275HP and 293TQ Pre Cam
    314HP and 303TQ post cam
  2. #12
    yeah, I did that, too. Cheap autozone push-on crankcase filters work great.
  3. #13
    San Marcos Texas
    blame your oil comsuption on your pcv system. ditch it and run 2 breathers and never worry again
    Same here!
  4. #14
    Apr 2005
    Ya, my 408 uses a quart per 3-4k miles.
    Gone, but not forgotten!
  5. #15
    Mar 2006
    Mesquite
    Can you expound on this please? Not real sure what you mean...
  6. #16
    engines develope a lot of positive crankcase pressure when running. The higher performance engines create even more. At high RPM the oil gets vaporized into small molecules and float all over the inside of the engine in a gaseous state. The PCV valve has a vacuum hose going to the engine that draws that vaporized oil and pressure into the intake manifold and then burns it, remember that dirty intake manifold problem you had a while back, that was from the vapors. Instead of drawing those vapors into the intake you put small air filters on the locations where the large vacuum lines connect to the valve covers and vent the crankcase pressure to the atmosphere. In return you get a cleaner running engine and less oil consumption.
  7. #17
    burlington,Co
    i went from using a quart ever 2000 miles to no oil loss just by putting on breathers instead of using the pcv system.
    2008 Trailblazer SS 2wd red jewel 1ss
    Forged 365,Tvs1900@11psi,IW 8 rib overdrive,duel pass heat ex,Prc heads,blower cam,Yank,Aeromotive,ect
  8. #18
    Greg is absolutely correct. That is the cheapest and easiest way to eliminate that problem. Or you could do a PCV catch can. A Catch Can just temporarily stores the oil. AMW makes a good product, but it is quite pricey...
  9. #19
    Aug 2004
    Houston, Tx
    are you just supposed to leave the hoses unhooked and do nothing about them?
    '04 Z71 5.3 Coldair kit, leveled, ranch hand bumpers
  10. #20
    Cap the hose off at the manifold.
