Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: fuel pressure questions.
    Jun 2007
    im good and clear now but,just messin ,red said pump then filter .so my buddy was right ,about the reg after the rails,humm.this time .we always get into arguments over the older stuff he does and the newer stuff i do .
    If you're doing a filter before the pump you still need one after it. A sock filter is there normally to protect the pump but the other filter after the pump is to protect the system from pump debris and smaller particles. You can do a 100 micron filter before the pump and a 40 micron after it.
    Jun 2007
    thanks red nice to know
