Results 11 to 20 of 21
Thread: 350 TBI to carb swap
  1. #11
    Feb 2008
    McAlester, OK
    So how easy would you rate that swap? I realize thats what every other thread is about but you know..
    92 Silverado, 15.7 @ 85, 350 TBI 700R4, 3.42s, flip kit, spindles, shaved tailgate, mirror fillers, 5% tint, 35% windshield, 235/60-15, 295/50-15
    02 Tahoe, 16.6 @ 88, 5.3 4L60E, stripped roof rack & steps & trim and badges, dropped 3 in. in the rear, smoothed and painted mirrors and handles, super 44
    www.fastassstreettrucks.com
  2. #12
    I would say the swap is very easy after doing three of them. If you get the wiring harness converted that makes it easier.
  3. #13
    Feb 2008
    McAlester, OK
    By converted you mean..?
  4. #14
    The wires need identified as to where to hook them up and fuses will be added to the power circuits. I'm not sure what all NelsonPerformance does when they convert a harness but it makes it very easy to add the wiring to the existing harness.
  5. #15
    Feb 2008
    McAlester, OK
    Ya i was thinkin they did it..its the electrical and comp stuff that gets me! What all do you need just as far as the wiring and computer stuff goes?
  6. #16
    just tie the right wires together and get fuel to the fuel rail at the correct pressure. Read the LS1 to OBS conversion topic a few times and see if you think you can pull off the swap. Grab your local buddies, a few cases of beer and have a weekend thrash for the big stuff. The small stuff will eat up your time for a week of evenings tieing up the loose ends.
  7. #17
    Feb 2008
    McAlester, OK
    so basically once you get the engine and tranny in then its mainly just about fuel system and a bunch of wires?
  8. #18
    yep
  9. #19
    Feb 2008
    McAlester, OK
    if I were to use the plug and play harness from Nelson would i just do away with my factory computer?
  10. #20
    yeah, you could but there is no reason to remove it, just cut the wires that aren't being used.
