View Poll Results: What size shot
Voters
27. You may not vote on this poll
  • 75 hp
    1 3.70%
  • 100Hp
    1 3.70%
  • 125hp
    6 22.22%
  • 200-250 hp
    19 70.37%
Results 11 to 20 of 33
Thread: Noitrous Kit
    Nov 2006
    Mesquite, TX
    a single stage 250 shot is to much of a hit....you will do nothing but blow your tires off even with slicks and a good suspension setup.....you really need to break it up into 2 stages...trust me
    How about a single stage with a progressive controller?
    Nov 2006
    Mesquite, TX
    that would also work very nicely
    Oct 2007
    Spring, Texas
    Tell Me MOre about the progressive controller. And will it work with a zex kit
    progressive controller is an electronic device that will regulate how much nitrous goes in initially and then you can ramp up and add more nitrous in stages. You can launch with a soft 50hp boost and 1 second later ramp up to 150 and a couple seconds later ramp up to 250 hp. They're totally controllable by programming. FJO makes a nice one and dynotunenitrous has one they sell, also, with analog/manual controls.
    Oct 2007
    Spring, Texas
    will it work with a timing controller or is it incorporated into it
    I haven't read everyone's responses, but you could do a dual stage...spray off the line with a 100 and then have a second stage hit at 125... Might help and save some wear and tear on the driveline...
    Oct 2007
    Spring, Texas
    I'm looking into the two stage set-ups and trying to figure out exactly what i want and need. two stages sounds like a great idea
    Nov 2006
    Mesquite, TX
    Quote Originally Posted by chevythunder View Post
    i run 2 stages on my truck....i can give you pics of how it is setup....first stage is on a micro switch with a nitrous plate and 2nd is on a button with a fogger nozzle....it can end up costing a lil bit of money...i ahev bout $1800 into my nitrous system, but i also run a stand alone fuel system for the nitrous
    Oct 2007
    Spring, Texas
    Pics
    Sounds good if you can send the pics to adamlongbotham@yahoo.com
    I would greatly appreciate it. I think i will start will a small single stage shot first until i've got more money. Thanks Again
