Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: Mounted my tach
  1. #11
    Dec 2003
    Azle,TX
    Quote Originally Posted by dared2k View Post
    that is exactly where i HAD mine. It looks great and doesnt really block you view. Here is the problem! Over time the truck vibration will weaken the plastic in dash. Mine broke off leaving a quarter size hole in my dash. The chuck of dash that broke off was still attached to the tach. I had the same tach as you. Unless you beef up the mounting point i am affraid you will shed the same fait that my dash did. thats just my 2 cents and story. Good luck! red2k
    Its braced under the mount and its thru the dash and the brace underneath.I almost drilled without locating the brace....and it would have broke out..thanks for the heads up
    Vortec Performance Tuned
  2. #12
    San Marcos Texas
    Quote Originally Posted by COWL327 View Post
    I took the airbag switch out and pushed it into the cavity,then I glued a plastic sheet to the back of the dash cover.Drilled a hole and removed the suction cup and epoxied a bolt to it then bolted to the plastic sheet.and it works great there
    Nice! That looks simple enough.
  3. #13
    Oct 2007
    Bentonville Ar.
    great, at least you didnt bone head it like i did.
    just a tow package
  4. #14
    Dec 2003
    Azle,TX
    OH...Ive done my share of that...trust me!
  5. #15
    For some odd reason, I honestly believe Dale...
  6. #16
    Dec 2003
    Azle,TX
    Here it is with the blue LED
  7. #17
    Southern California
    are you really revving your engine to 6700 rpm?
    2007 NNBS 4.8 -k&n, magnaflow, 8000k HIDS.
  8. #18
    Dec 2003
    Azle,TX
    NO...key on not running
