Results 1 to 10 of 18
Thread: Mounted my tach
    Dec 2003
    Azle,TX
    Quote Originally Posted by GMCwantsLS1 View Post
    Looks great! I was thinking about mounting my Garmin in the same spot as you. Does it work well there? How did you mount it?
    I took the airbag switch out and pushed it into the cavity,then I glued a plastic sheet to the back of the dash cover.Drilled a hole and removed the suction cup and epoxied a bolt to it then bolted to the plastic sheet.and it works great there
    Vortec Performance Tuned
    San Marcos Texas
    Quote Originally Posted by COWL327 View Post
    Nice! That looks simple enough.
