Results 11 to 20 of 43
Thread: New LS2 intake and 90mm Nick Williams TB for the 408
Threaded View
    Well, I leaked it out earlier so I figured I'd start a topic concerning the swap from a stock LS1 intake with the factory 98 T/A throttle body to an LS2 intake with a 90mm Nick Williams throttle body on my 408 engine.
    Special size O-Rings and fuel rail spacers for LS1 type fuel injectors. PN KATA4096
    Fuel Injectors, Fuel Rail Spacer Kits & Fittings Katech has developed kits to adapt the Gen 3 LS1/LS6 style injector into the LS2 or LS7.
    KAT-A4096 LS2 adapter kit
    Price $24.99
    An extension for the MAP sensor is needed. PN KATA4751
    KAT-4751 LS2 / LS7 MAP extension harness
    • Extends the MAP sensor wire to the front of the manifold
    • High temperature loom
    Price: $26.99
    Both parts are available from SDPARTS.COM
    Intake and throttle body acquired on LS1Tech
    I'll try to remember to take some photos and document the process as I change the intakes out.
    Last edited by RedHeartbeat; 01-10-2008 at 02:10 PM. Reason: added PNs for extension and seals
