Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: red hb.contd from last night!
  1. #11
    Jun 2007
    maybe i could just set the speed controller on my aero system to cut in sooner ?would that be the same thing somewhaat?
  2. #12
    Put it as close to the intake as possible in the cold air pipe. I'm not an expert on boost at all. I just know how it works. I've never had a boosted LSx engine that I've built so I'm not really sure what the solution is but I'm trying to analyze what's going on and what may fix it.
  3. #13
    Yeah, you could setup the pump to boost the pressure earlier but it doesnt need to be maxxing out the pump voltage when the engine isn't under load. The hobbs switch will turn the pump up when pressure is present.
  4. #14
    Jun 2007
    instead of coming on at 3k ill set it to come on at 2-25k how that sound?thats my billet speed controller.cause if i have it in tow haul it dont do it.
  5. #15
    Jun 2007
    so i could use both?if ness.the hobbs also?and what wires would i connect 2 on that i see it ha s 2 .would it be my fuel pump wires or what wires do i hook the hobbs 2. ithink were getting somewere her i appreciate the patience red.
  6. #16
    Wire the Hobbs switch into the manual override terminal at the bottom of the connectors. Its a ground wire. Run a wire from the terminal at the controller to the hobbs switch and then on the opposite side of the switch run the wire to a ground. Adjust the hobbs switch to trigger on at 2-3 psi.
  7. #17
    Jun 2007
    cool ill try it if i dont blow it b4 i get it ,im pretty scared now that its popping,i appr all the patience and knowledge red thanks ill keep u posted .
  8. #18
    yeah, that will be a ground circuit for the SWT terminal.
