yea for sure
yea for sure
Dropped Ext Cab 99 Sierra, AirRaid intake, PowerAid Throttle Body Spacer, 3 in exhaust to a Flowmaster, Exhaust out back side of bed of truck, Bright Red, Projector Headlights, Billet Steering Wheel, Touch Screen DVD/CD player, Soon To have, N2O, Headers, Cam, Stall, Nelson Tune, E fans, Shift Kit,
I picked up a second in the 1/4 with no other changes.
Check the bolt pattern on the valve covers!! Redheartbeat is right, some LS1's will have a perimter style valve cover and will require brackets for you to mount the coil packs. You shouldn't have to buy the LS1 coils at all. If by chance the LS1 has a center bolt pattern style valve cover then youre ok with the truck coils and brackets. Fuel injectors will be fine since they're only 4lbs less than the LS1's you shouldn't see too high on the IDC.
what would i have to do since i have a 4.3 in my truck. Would i need the ls1 wiring harness and computer. Also is it possible to put a 6-speed in a single cab 2001 chevy.
