2004 Silverado , 5.3, 22" akuzas, SS bumper, cowl hood, lots of winter power upgrades coming.
1990 Sierra ST 540, prostreet **SOLD**
Not to mention the fact that the 370 will live longer and rev higher than a 408.
to be honest, thats pretty much just the advice ive needed all day...its not often the cheaper choice is the better choice..i know my wife would appreciate this decision..if i was to ever tell her
Thanks guys
Hell, just do a 347. You can still make "Hella" power with one. I have seen people make 800 +rwhp with boost.
That way, you can start with a cheap 5.3 iron block.
Yeah, but a 408 chews the piston skirts up from the first time you crank the engine. The cast iron block has cylinders too short for a dependable long life with a longer than stock stroke. If you precision balance both engines the 370 will run sustained high RPMs much longer than the 408 ever will.
When the cylinders are as short as they are in the 6.0L the pistons tend to rock in the cylinder at the bottom of the stroke and the bottom edge of the cylinder cuts the skirt. I have some wonderful pictures of the damage a 4" stroker does to a 408" engine. Yeah, I know a 4" stroke works on some engines but it doesnt work on all engines. A 4" stroke is great in an aluminum block GenIII but the cylinders are longer and the pistons stay stable at the bottom of the stroke.
single digit street truck
for build info
OK, so now ive got another question.
i found a great deal on a set of stock size ls1 rods and pistons and crank. can i put those in my 4.8/ 5.3 L block?? and just bore the block 30 over???
I'm right now working on a 5.3 to 5.7, and found good price in a mahle kit
eBay Motors: H-BEAM RODS MAHLE PISTONS SBC SB CHEVY 6.1 LS1 LS6 RP$ (item 260126062683 end time Dec-02-07 21:56:50 PST)
The Pistons R ceramic coated and with graftal on the skirts, the rods R preatty nice, eagle I think.
I ordered the lowest CR cause I'm on Turbo, so CR would be around 8.8-9.0
