Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: Which Gears?
  1. #11
    San Marcos Texas
    I think what it comes down to is a NA engine makes its torque peek high in the RPM range you need higher numerically gears to keep it in this range. With a turbo you make a broad flat torque curve when under boost so you load the engine with numerically lower gears to force the turbo into boost. In other words you are cruising along with no load and no boost, but you put a trailer or climb a hill you start making boost and thus more torque.
  2. #12
    Feb 2005
    OK then I'll try to take the truck to SAR for the retune this friday or the next with my current setup (3:42) then when I get the new rearend which will be 4:10 we'll see what happens and if its better I'll keep it that way if not I'll go back to lower numerically gears.
    2001 GMC Silverado
    Stock Bottom End LQ9, MS3, Stock 317's, Victor Jr, Aron's Elbow, 90mm TB, 1 7/8 TSP headers, FLT 4L80-E, Rossler Trans-Brake, 3600 PI TQ, 4.10's, 31" tire. Nitrous Dave System with Zex plate. On 150 shot 10.53 @ 128MPH 1.51 60'
    Old Setup = Trick Turbo Kit Tuned/Installed By Nelson Performance 10.78 @ 127.08 1.62 60'
  3. #13
    San Marcos Texas
    I don't remember the exact setup, but Allen already proved this in the old truck with the STS.
  4. #14
    So, would it be better to reprogram the PCM to lower the shift points since the power is down low instead of up high?
  5. #15
    San Marcos Texas
    It's ok just get 4.11's.
