Page 19 of 30 FirstFirst ... 9 17 18 19 20 21 29 ... LastLast
Results 181 to 190 of 299
Thread: 5.3L (LM7) into OBS Silverado
  1. #181
    Oct 2005
    Baton Rouge, LA
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Jul 27 2006, 01&#58;12 PM) [snapback]59178[/snapback]</div>
    The same circuit that feeds the tail lights brake power can be used to trigger a relay to cut the power off for a TCC. Hook terminal 30 to the brake light wire, 87 to ground, 85 to a switched 12v power circuit and 87a to the transmission TCC power supply wire. When you step on the brake, 12v will activate the relay&#39;s coil and disconnect power from the TCC, releasing the lockup convertor.
    Sent you a PM. Kinda long, but not too bad.
  2. #182
    Yeah, the terminal numbers I was speaking of are the ones on a Bosch type relay.
  3. #183
    Oct 2005
    Baton Rouge, LA
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Jul 27 2006, 04&#58;12 PM) [snapback]59194[/snapback]</div>
    Think I have that licked. Spliced that brake light to the E connector (Brake Pedal Switch Output - Torque Converter Clutch). Drove around a bit, and haven&#39;t gotten those DTCs again. Although driving the truck now seems like the TCC is enabled when pulling off from a dead stop, but it&#39;s not. That could also be in the tune. I guess I need to spend more money to have a tuner look at it, and fix what&#39;s wrong.
  4. #184
    Oct 2005
    Baton Rouge, LA
    Still don&#39;t know whether or not the brake switch mod is locking the TCC. Not really concerned at this point. Good news is....
    *drumroll please*
    Trucks running great&#33; Thanks to all that have assisted with suggestions and such&#33; Now, it&#39;s time to save a few ducketts for a few dyno pulls. I&#39;d like to have an idea as to where the numbers sit. Then, I can tune from there. Been having a bit of fun this week. I can spin through 1st & into 2nd. 0 - 60mph is accomplished in 6.3s. Not bad, but descent enuff since my &#39;02 Yukon can do that in 9.2 (and still clock 15.88s in 1320). I&#39;m feeling more confident about the high speed vibration. Wondering if that has something to do with the "po-man h-pipe" setup I have. I spin the d-shaft up to 6200 (yeah, truck pulls that high), and don&#39;t feel anything til about 90-ish. Trans is in good shape. Wondering if exhaust pressure is trickin&#39; me into thinking it&#39;s a driveline issue? Ah well... just thought I&#39;d share.
  5. #185
    Oct 2005
    Baton Rouge, LA
    LOL... guess who passed emissions with no cats... JFWY&#33;
    Question... NITROUS, was it you that posted a pic & link for a part for AC systems? I&#39;m looking to gather parts that I need to fab AC stuff I need to get cool air blowing in my C10. If anyone remembers, please post. I&#39;ve been searching for two days, and have not gotten lucky yet.
  6. #186
    Jan 2006
    Las Vegas, Nevada
    1BadC10,
    I got this info from Nitrous previously.
    The seal kit is AC Delco #15-20058. I got mine on Ebay but Nitrous says any auto parts store that carries AC Delco should have it. And here is the web site for the line block. They also carry fittings. I got one 90 degree and one straight fitting.
    hope this helps&#33;
    1965 C-10 shortbed stepside, 2003 5.3/4L60E conversion. Power steering, tilt wheel, power front disc brakes, 3.73 one wheel peel, 2.5/4 inch drop, relocated fuel tank and battery, 2002 Silverado buckets and console. Swap Pics
    1968 Camaro 95LT1/4L60E lots o' mods Web Page
    1961 Corvette project.......... C-4 suspension and brakes, 02 LS1/T-56 awaiting installation Pics
  7. #187
    Oct 2005
    Baton Rouge, LA
    Ahh... GRACIUS, MI AMIGO&#33;&#33;&#33;&#33;
    I&#39;ve searched the net for everything but "A/C Hose Block".
  8. #188
    Jan 2006
    Las Vegas, Nevada
    De nada
  9. #189
    Oct 2005
    Baton Rouge, LA
    That, and associating parts, should be posted in a Sticky up top.
    <---- along with her&#33;
  10. #190
    Jan 2006
    Las Vegas, Nevada
    Oh, and BTW... while I think I have all the parts I need, I still haven&#39;t got around to putting my A/C system together........ In fact I still haven&#39;t finished the Camaro&#39;s A/C and I&#39;ve had that swap "complete" for almost 10 years....
    <div class='quotetop'>QUOTE(1BADC10 &#064; Sep 11 2006, 04&#58;46 PM) [snapback]64742[/snapback]</div>
    <---- along with her&#33; [/b]
    OOOhhhh, he said "sticky" while pointing at her&#33;
