Page 16 of 18 FirstFirst ... 6 14 15 16 17 18 LastLast
Results 151 to 160 of 220
Thread: ***Official DFW LS1Truck meet August 2008***
    sprayed99 Guest
    I will be there! anyone that might need a place to stay I have an extra room!
    for any of you guys that are virgins to an NHRA track, wear long pants or have them to change into. Shirts with sleeves are require, short sleeves are okay but no sleeveless shirts. Also, if you think you might run faster than an 8.59 in the 1/8th you WILL need a helmet and they no longer cut you slack, no helmet no run. Most tracks require a driveshaft loop if you run slicks but they have not been stopping me for that.
    I might need to borrow a helmet NOT
    Oct 2007
    Well I got there late since it was a long drive for me and got in 3 runs. Full street trim with step rails and hitch and around a 3rd tank of fuel. I did ok considering the heat and my weight.
    rt .1296
    60' 2.3146
    330 635997
    1/8th 10.0898 @ 70.50mph
    2008 Nissan Titan Crew Cab 4x2
    426hp and 444tq at the rear wheels
    Met some guys last night from the site. Northstar is my "home track" was impressed to see so many guys from here come so far to our little track. Thought I'd join up just to say hi to those I met at the track.
    Yeah, I'm there most every Friday if I don't have something else going on.
    Mar 2006
    Mesquite
    It was good seeing everybody.
    Next time I'm gonna keep up with you Greg.
    I'm going to weld a restrictor plate in your turbo down pipe.
    Mar 2006
    Mesquite
    Not a problem. I can cut steel - just can't weld it.
    good meeting you finally Moze. dont tase me bro.
    i had some good times too, it was so hot.
