Page 14 of 28 FirstFirst ... 4 12 13 14 15 16 24 ... LastLast
Results 131 to 140 of 273
Thread: Lost 3-4 clutch pack...exploring options...
  1. #131
    Dec 2004
    San Antonio, TX Area
    You will get it, it is just very frustrating and annoying. Don't let it beat you, it will be awesome once you are done.
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
  2. #132
    I didn't see a post about codes you got. I just thought you was wondering what the parts were. Louis didn't mess with the transmission parameters, did he? The converter usually works or it doesn't. If it's the TCC solenoid then you usually wont get any lockup unless it has a short somewhere. If it were mine I'd put a 46mod vacuum control kit in the transmission with a forced induction bypass kit. I've just grown accustomed to the kits and like the consistency.
  3. #133
    Mar 2006
    Mesquite
    You even posted in it bud. click
    Not sure what, if anything at all Louis did with the trans...maybe nothing.
    Does PATC carry the vac control kit? Going to look...
  4. #134
    Nothing we did has anything to do with the DTC's you have. We reused the harness (that also includes the PCS) as well as all the VB stuff. My guess is on converter but there is a chance the TCCS is leaking. I doubt it has an electrical concern. On that note, the fact it had this before should not make a difference on the build we did assuming the pump pressure is good.
    I'll do some more research and post back up...
  5. #135
    Oh, those codes were from your truck? I was screwing around. I forgot all about that post.
  6. #136
    OPT has the best prices on those parts. Drive using manual 1st and 2nd and you should be good until we can get the vac kit installed.
  8. #138
    He needs a meter and a scanner so we can diagnose...but you've got a good idea too.
  9. #139
    Mar 2006
    Mesquite
    Easy install?
