<div class='quotetop'>QUOTE(airdeano @ Jul 16 2007, 06:37 PM) [snapback]99666[/snapback]</div>
chuck21387,,
were hitting' on all eight.\
well soak 'em overnight to get the crud outta 'em.
nasty, nasty, nasty... you want the ick left in the bottom
of the solution?
<<<< shiver >>>>
airdeano
Nasty is right...when you can look in the injector and see brown crustys....things are bad....real bad!!
but you know what airdeano? for all your hard work, i'll let you keep the sludge in the bottom of the cleaner! really, i can't say a big enough THANK YOU for what you did!!
Guys....this guy is "da man" and here at work, if you get 3 "da man's" before quittin time, you get to go home early :-) i've made it to two once...so here's your first one for the day! YOU DA MAN!
2000 PSD F250 Super Duty Ext cab long bed 4x4 - a few mods...450+ HP 500+ lbs of torque!! (Daily Driver)
1993 YJ "Buggy"
1991 3/4 ton Suburban 6.2L turbodiesel
