Results 111 to 120 of 137
Thread: Current top secret project
Threaded View
    I may have to delete this but here goes...
    Subject: 1993 RCSB 2WD GMC C1500
    New power plant: 2002 5.3L with LS6 camshaft and orange stripe springs
    New transmission: 2002 4L60e transmission with a bunch of goodies inside it
    Some goodies in the trans:
    Art Carr 9.5" converter
    Superior 1-2 billet servo
    Superior 4th billet servo
    Transgo hardened valve body plate
    Aluminum pistons replacing the plastic ones
    4L60-HD2 shift kit
    Transgo Vacuum shift pressure controller
    Engine is bolted in using Ebay style adapter plate, Gen1 V8 truck mount cups and Oriellys sourced 5" long mount bolts.
    Energy Suspensions polyurethane transmission mount went in since it needed something there.
    Engine is full of Castrol 5w30 with a WIX filter. Plate above the oil filter is tapped 1/8"NPT, 1/8 x -4AN fitting is installed and there's a 6' long -4AN braided hose ready to feed a front mount turbo one of these days. If it proves to be too long I have a 4' long hose ready to take it's place. A 3/8" NPT hole was drilled and tapped in the front right corner for a -8AN fitting. I drilled the pan and then removed it from the engine to clean the chips out, they went everywhere.
    The factory transmission cooler hoses went back in without a hitch, lonely for a radiator now.
    The starter was crushed somehow, I beat it back into shape and it works but I don't know for how long, maybe forever, maybe 15 seconds.
    I know the lucky person getting the half finished project wants it but A/C isn't much of an option since something huge is taking up the entire front of the radiator core support area where the A/C condenser normally goes.
    Next:
    driveshaft
    Fan belt - done
    1998 model vortec v8 throttle cable - done
    exhaust o-rings x 2 - done
    Start fabricating an exhaust crossover pipe - in process
    Bigger fuel injectors
    Hair dryer looking thing - here
    build a down draft tube for hair dryer looking thing
    Forgot it needs an air cleaner to keep hair from getting sucked into dryer.
    Air filter - waiting on delivery
    Battery tray - done
    34" radiator and electric fans - delivered
    re-run all underhood wiring to front end lights - done
    re-run the 1993 factory engine harness
    pray that a Nelson wiring harness finds its way home before I have to bastardize the 2002 stock harness for use
    SummitRacing.com polished aluminum billet GMC grille insert?
    Install fuel tank with sump setup
    Install Bosch 044 fuel pump and Summit fuel filter
    add OnStar or a built in satellite phone to call a tow truck when the rearend melts down
    That ought to take a couple hours to finish up.
