So here's what i started with,
1993 Jeep Wrangler (YJ)
2.5L 4 cylinder (125ish HP)
5 Speed Manual
NP231 Transfercase (Aluminum chain drive)
Dana 35 rear axle (Stock) w/ factory 4.10 gears
Dana 30 front axle (Stock) w/ factory 4.10 gears
What i have to install
2000 GMC 5.3L Vortec V8
700r4 Auto transmission
NP208 transfercase (aluminum w/chain drive) i do have a Dana20 tcase (gear drive cast iron case) that will go in at a later date.
Corporate 14bolt rear axle shaved 1.5" for max rock clearance (cut 2" off the bottom of pig, weld on 1/2" plate, and turn ring gear down 1/4")
Dana 60 front axle both with factory 4.56 gears
Should be a fun toy in the end!!
