Results 101 to 104 of 104
Thread: Redheartbeat
Threaded View
    Redheartbeat
    I'm just starting this so give me a little while to compile some photos. I don't take many.
    My signature information below since I can now delete my sig in my online profile and post a hyperlink to this "My Garage" post...
    This is where the madness began, or should a say ended when it was stolen and I had to start all over again...
    I bought this new in Oct of 1992, went 2/4 down, went 10" up (never will do that again) and came back down to a 4/6. In the time from when I bought it to when it was stolen I had put over 300k miles on the truck. It started new with a v6 and 5 speed, got a 93 LT1 transplant that killed two more 5 speeds and then finally an LS1 and 4L60e. The early Escalade front end was thanks to a Lincoln Mark8 that got t-boned when he pulled out in front of me from a liquor store.
    My last ride...
    1993 C1500 Ext cab
    2WD
    2/4 Beltech lowering
    steel rollpan from StylinTrucks.com
    billet grille from SummitRacing.com
    Crystal clear chinese headlights, turn signal and corner marker lights from Ebay
    Inexpensive paint refinish job via Maaco
    HI-4 headlight conversion
    Engine:
    V8 to 98 T/A LS1 conversion and then replaced the 5.7L with an TRTTURBO/HKE forged 408 stroker
    2002 Fbody wiring harness
    Patriot StageII heads
    Scorpion aluminum 1.7:1 ratio rockers (thanks Bulldog5.3)
    Comp Cams XE-R XER287HR
    Longtube headers custom built from Hooker BBC headers and GMPerformanceParts flanges
    Transmission:
    2002 4L80E
    3500 RPM 9.5" Vig 3 disc converter
    Transgo 4L80e-HD2 shift kit
    Transgo 48MOD vacuum controlled pressure modulater
    PML cast aluminum trans pan
    Tru-cool 40,000 gvw transmission cooler
    NelsonPerformance.com 60e to 80e transmission harness adapter
    Rear End
    14bolt rear end
    3.42 gears
    Eaton LSD (broken and now has welded spider gears for a full spool effect)
    Caltracs
    Cooling:
    34" radiator
    '05 Silverado electric fans
    Street and Performance high right side a/c mount with Sanden compressor
    Exhaust:
    Longtube headers built from Hooker BBC headers and GMPerformanceParts flanges
    Magnaflow 3" cats
    Magnaflow muffler with 2 3" inlets and 2 3" outlets
    3" true duals all the way out the back
    Intake:
    custom CAI under core support
    K&N air filter
    Fuel:
    Walbro 255LPH in-tank fuel pump
    Corvette internally regulated fuel filter
    RACETRONIX fuel pump hotwire kit
    42 lb @ 43 PSI Lucas/Delphi fuel injectors
    LS2 Intake
    90mm NickWilliams TB
    Edelbrock billet fuel rails (Thanks Mean05)
    -8 fuel line from filter to rails
    Fun stuff:
    Nitrous Outlet plate nitrous system with -6 supply line good for up to 400 additional RWHP
    Standalone fuel cell for the nitrous solenoid
    Progressive Nitrous controller
    Tune:
    NELSON PERFORMANCE speed density tune in a 411 PCM with a 2002 Camaro base tune shifting the 4L80e with a custom transmission overlay in the PCM
    New wheels, waiting for the correct center caps to come in.
