ok...found it!!!...it has something to do with the small plug on the neutral safety switch.....which the wires are
blue plug
32
BLK/WHT
771
Transmission Range Switch Signal A
34
WHT
776
Transmission Range Switch Signal P
72
YEL
772
Transmission Range Switch Signal B
red plug
62
GRA
773
Transmission Range Switch Signal C
....and with 3 different harnesses and 2 different neutral safety switches and still having the same prob in every case,which makes me think it could be a problem with the tune...what do you guys think?
with everything plugged in besides this plug the temp gauge doesnt jump around and seems to be reading right.
i cant get anyone at nelsons to return my calls....i guess i can put my ecu in a buddies truck and see if his does the same thing...will this work?
what will happen if i leave this unplugged and try to drive it?
