Page 10 of 13 FirstFirst ... 8 9 10 11 12 ... LastLast
Results 91 to 100 of 124
Thread: need help with swap 4.3-5.3
    Get a test light or multimeter and check the grounds from the PCM to the block. Check Red 1 and 40 Blue 1 and 40. They should be dead shorts to ground. Also, check continuity on Blue 74 to the yellow wire on the coolant sensor. Did you replace the coolant sensor?
    wichita falls, tx
    i ordered a coolant sensor it will be here on fri.
    Intro Radicalli's
    wichita falls, tx
    how bout if i unplug the coolant sensor and see what that does...if it is unplugged and the gauge still jumps around that would indicate a short right?...and i will check the grounds on the pcm when i get off...now that i know which pins they are..thanks man
    Intro Radicalli's
    while you have the connections off the PCM verify that the metal pins for the wires are all sticking through the same amount on the PCM connector on the harness.
    Quote Originally Posted by banker099 View Post
    Not necessarily, it could be a short in a wire instead of in the sensor.
    Oct 2006
    houston
    hey banker how is the truck doing so far
    wichita falls, tx
    man its running horrible...still cant find the prob.....all the grounds are good on the pcm plug...any more suggestions?
    Intro Radicalli's
    Jun 2007
    maine
    watch its going to be something really easy and dumb and youll just be like are you kidding me...
    good luck man
    wichita falls, tx
    well...i swapped harnesses today and the temp sensor still jumps around as you move the column shifter....changed the coolant temp sensor in the head...still same...i have an extra neutral safety switch i guess i will change it tomorrow, since the prob seems to be related to the shifter....truck runs good now after the harness swap ...if i ever get the temp prob fixed i will be a happy man!!
    Intro Radicalli's
    Great! Now just find the short. May be inside the steering column.
