Dudes,
LT1 recive 42 injectors nice
Thanks in advace
Gabe
Dudes,
Thanks in advace
Gabe
Need a Freakin' Roll Cage, and a Death Insurance
Have Allen send you the new injector connecter ends- You have to cut old ones off and solder new ones on. Also ask him for some spacers for under the fuel rail mounts.
Is that was suppost to come with the kit or is like MATTEL???
EACH SOLD SEPARTELY!!!!!!!
Damn..........all this exitement for nothing....that piss me off dudes.
Sorry
Sounds like he sent you injectors with fbody connections. He must have assumed you had the square connectors already.
Last time he sold me the original 42 for no hassle instalation, wich it was.....
Know we R just an e mail to ask
The 42's are direct replacement, but the 60's Allen's shop replaced the connector ends when I was there.
Dudes, I found locally the electrical conectors, but not the Clips.
Checking the stock vs the bazooka size injectors notice 2 clip land. In the first is not at the same heigth as the stock to fit in the fuel rail, but if I put the original clip in the second clip land they look and meassure almost the same!!!!!!
I put pictures for u to know What I mean......
Can I go for it, cause the other spacer for the bolts and loger bolts for the fuel rails is piece of cake.
Send me help with ur knowledge dudes
Thanks in advance
Gabe
Free Photo Album with PicTiger
looks like you got it covered, remember to put some lube on the o-rings before installing.
<div class='quotetop'>QUOTE(foggy @ Dec 14 2006, 07:11 PM) [snapback]76346[/snapback]</div>looks like you got it covered, remember to put some lube on the o-rings before installing.
[/b]So you think it'll work?looks like you got it covered, remember to put some lube on the o-rings before installing.[/b]
I like Lubrication a lot....hahahahaha
I allways use it, 3rd injector change, with out counting the one that I took all them out to put the 60 to find out they did not fot in any way !!!
Damn I was mad!!!!![]()
That is only my fault for let my exictment cloud my triple check routine....hate me, and me, and sometimes I hate me too!!!!!!!!![]()
Any more Opinions, I wanna go shure!!!!!!
Don't forget to shim the fuel rail up about 5/8" (I don't know the metric conversion). You will need bolts that are longer as well.
Gone, but not forgotten!
