Dude,
I want to use the 200hp shot on my motor. I sprayed 3 times, but with the platinum plug and probably a lean tune.
Add that a almost like water oil, and the result was a cap busted.
What was ur problem with the Nitrous? I know the bottom end can hold it and have forged pistons and use only race gas when using NOS (110+oct), but is there a tune issue.
I have a wet ZEX system.
Have a walbro replacement pump in the tank and a Wlabro aux in line that Allen send me, have 42 injectors.
Check the presure at wot and check on 52-53psi all the time.
Can you lead the way?
