Results 1 to 10 of 22
Thread: installed servo
    hey i installed the corvette servo in my truck and dam im amazed with the shift points.i installed it friday night sorry for the lateness.but when i was crusing on friday night in my hometown there are some smooth roads where i live.so i got to a red light in a smooth road i took off half throttle and in 35mph the tires chirp i was like dam this was the best 15 buck on a part
    Sep 2006
    Coon Rapids, MN
    glad to here that you put one in. it makes a bit more fun to drive
    04 Grand Prix GTP
    03 Z71 wanting a Turbo ,Stall, and Tune BAD
    THE SURGEON GENERAL SAYS NOTHING ABOUT SMOKIN A FORD
    Jun 2005
    Round Rock
    Now get the truck tuned to better utilize the servo and you will be twice as happy!
    Congrats
    08 HHR SS
    Black on Black 5 spd with no options
    Pics of Christine, the '05 VHO My Car Domain Site
    May 2006
    Waco TX
    Where can you get corvette servos and how hard is it to install?
    DBYRD Guest
    sounds nice, but i though tthey were kind of hard to install. im not an expert, so idk id prob break some shit and end up spending like 1000 to fix what i messed up haha. glad to hear u got rs going tho, congrats!
    May 2006
    Waco TX
    Where can you get them?
    May 2006
    Waco TX
    Also is the installation the same on a 4wd as it is on a 2wd. That article I believe talked about a 2wd. I went to the link the article suggested, but I cant find corvette servos for a 65e or 60e. Just billet servos. Would the 60e and 65e be the same?
    You can buy them directly from the dealer or any transmission supply parts company. Just be forewarned that if you do not get it installed and seated properly you can crack the transmission housing, causing a huge leak and replacement of the housing. Be sure you get the snap ring installed in the transmission case properly before you start the engine and place it in drive. If you are not too sure of your abilities it is best to have a shop install the parts for you for a minimal charge, should be less than $100 IMO.
    Nov 2006
    Plano, TX
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Nov 28 2006, 02&#58;51 PM) [snapback]74775[/snapback]</div>
    ... Just be forewarned that if you do not get it installed and seated properly you can crack the transmission housing, causing a huge leak and replacement of the housing. Be sure you get the snap ring installed in the transmission case properly before you start the engine and place it in drive. ...[/b]
    I&#39;ve made this mistake - it sucked bad. I did not break the case but did have to remove the tranny to recover the stuck servo (it was cocked/lodged in the bore); fortunately in my case I was able to clean the servo bore with 400-grit and saved the original case. Make sure that the snap-ring is seated all the way around, especially at the top of the servo bore.
    Mr. P.
