I have multiple tie rod flip kit inserts which allow you to relocate your tie rod through the bottom up on the spindle. These are used when you lower your vehicle in the front to prevent dangerous unwanted Bumpsteer. If you have bumpsteer after lowering it is because of your tie rods angle.
The inserts are super easy to install, shouldnt take no longer than 1hr
All thats needed is an 11/16th drill bit and a 3/4-16 tap!
Price is $40.00 set/ shipped
The inserts that you see on some suspension sites range from 50.00- 70.00+ shipping and you cant use them because they use a special Tap (3/4-20) which forces you to buy the expensive kit to recieve the tap, the ones i have on the other hand allow you to purchase the bit and tap from NAPA Etc.
These Inserts are Grade A, they are CNC Machined to allow a perfect fit, everytime.
Specially made to fit 1999-2006 Chevrolet Silverado 1/2 ton 2wd models, Or any vehicle with those particular spindles!
I dont do alot of posting around here but i have a 100% positive feedback at LS1tech.com and Performancetrucks.net
Thanks for looking!
