what kind of gear ratio should a 95 z71 have from the factory
'13 silverado LT...stock
'11 lt 4x4 z71..tvs1900
3.73 / GT-4 code
<div class='quotetop'>QUOTE(bud8fan @ Jun 1 2006, 09:02 PM) [snapback]54509[/snapback]</div>what kind of gear ratio should a 95 z71 have from the factory
<div class='quotetop'>QUOTE(bud8fan @ Jun 1 2006, 09:02 PM) [snapback]54509[/snapback]</div>because i do not want to mess up my transfercasewhat kind of gear ratio should a 95 z71 have from the factory
i think i should call the dealership and have them search the vin number an see for sure
373 Thats right!! Whats wrong with your transfercase??
2001 GMC Sierra C3 with the 6.0! Vararam King Cobra, TB bypass, No cats with two 3 inch cut outs and thats it for the motor. FOR NOW ATLEAST!!
9.5 in the 8 mile
6000K xrtalight h.i.d kit
When did you buy a '95 4x4?
that wasnt me...that was joey ..my sonhe blew his rear end and wanted to know what ratio was in it and i didnt know....told him to get on here and someone would know...thanks guys
Be careful, I had a 94 ECSB Z71 that had 3.42's. They did come with different ratios. If there is no tag, you'll have to pull the cover and count the teeth.
2011 Silverado LT 5.3 bone stock(for now)
(gone but not forgotten)02 Avalanche Z-71 Vortech supercharged 3.12 pulley 10psi, SMC meth injection, 33 12.50-17 procomp AT, 17x9 procomp wheels, AVIC-N2 NAV, 4.56 gears, Detroit TrueTrac, 2500 stall converter, transgo HD2 shift kit, Vette servos, 80mm BBK throttle body, Edelbrock shortie headers Cold Fusion wet shot (60hp), and too many more mods to list. 8.86/18th 472rwhp/499rwtq
Start by looking at the codes in the glovebox.
GT4 3.73 (most likely)
GT5 4.10
GT7 3.33
GT8 4.10
GU2 2.73
GU4 3.08
GU5 3.23
GU6 3.42
GV2 5.83
HC4 4.56
HC7 5.13
HE3 3.07
HF7 4.56
HF8 4.88
Hope this helps![]()
what kind of vehicle would have 5:83s in it?
You never know![]()
Found the codes, never found out where some of them came from but always nice to know more than I need.
