My vehicle has 3.73 ratio for the rear end. 5300 Vortec with 3.73 rear end Since it is 4WD, I would rather not go to 4.10 since I have to change both gears. The book says the max capacity is 7500. However the 4.10 ratio one gets to tow 8500. Why the difference? Because the RPM is higher from the 4.10 gears?
Also The trailer dry weight will be 6000. Add about 1500# of ATVs and a few items and that should bring me to about 7500 and a couple more for other misc stuff. I would estimate that it shouldn't exceed 8000 . I will have a weight distribution hitch with the sway controller.
The good part is that I have Dynatech long tube headers, Transgo shift kit, larger transmission cooler and Billet Transmission servos and a Granatelli Intake. Also I have got Jesse to take out all torque management and abuse mode. Is this going to be enough or should I have to do more modifications? TIA
- You may not post replies
- You may not edit your posts
