Results 1 to 10 of 13
Thread: 5.3 Port & Polish Throttl Body
    Aug 2005
    Spring, Texas
    Was wondering where to get a TB Ported And Polished, how much HP can you gain from this over buying an aftermarket 80MM TB?
    06 TrailBlazer SS LS2 4.10's
    02 SC StepSide Factory Orange
    Full Bolt-On 370 - Little Cam- Victor Jr Intake -Worked 5.3 Heads - 4.56's - Built 60E - Circle D 4000
    07 CTS-V CAI, GM Performance Exhaust, Ported TB, Coil Overs
    Jan 2005
    Humble/Houston TX
    do it yourself and save some money for better mods. this aughta help alot
    http://www.ls1camaro.net/sections.php?op=v...rticle&artid=16
    old mod list: H/C/I/N/E/G 408
    Aug 2005
    Spring, Texas
    THNX Man
    Jul 2005
    Galesburg Il
    I wonder why that "bump" was engineered into the throttle body to begin with and I wonder how for down you can grind it before you grind through it? I wonder if grinding it is a good idea? ...... or not!
    2002 white Silverado ext cab. Taillights filled, roll pan w/93 Cad lights horizontally placed, tailgate handle inside, Gaylord tonneau, bed slide & bed rug, all trim removed, Escalade door handles, 18" Enkei & Falcons, Speed grill. Grill shell, bumper pad, & valance painted white. Mirrors painted white. Many interior pcs painted black (over beige), black leather seat inserts and sun visors. 2" dropped DJM lower control arm, shackles/hangers for 4" rear drop. Engine: 5.3 , Radix w 2.8" pulley, 90 mm throttle body, Dart 225 heads, Comp Cam 581-588 224-230 on 114. ARP head bolts. KTech rod bolts. Alky Control methanol injection, Pacesetter lt's into elec cutouts then 4" polished Magnaflow SS mufflers then 4" ovalized SS pipes exiting in front of rear wheels both sides, gas tank removed and 24 gal. fuel cell where spare tire was w/Aeromotive pump, pre and post filters and pump controller & -10 SS fuel line. 160 thermostat MSD wires & Perma Cool fan, 34" radiator, Meziere elec water pump. Valve covers, alternator & brackets powdercoated white. Built 4l60e, 4.56 with Detroit Locker Trutrack. 2 Interceptor logging guages, FAST dual 02 sensor wb gauge, Cyberdyne vac/boost gauge. Truck is actually the property of a little Benji type dog. Pics of him and the truck too www.swardphotos.shutterfly.com
    Jan 2005
    Humble/Houston TX
    not sure but i would recomend using one of those big tweezer lookin thingys that you pinch down to see how thick the material is. not sure what the technical name for them is but do you know what im talking about?
    i already have a shaners ported throttle body but im thinking about buying a spare and giving it a shot just for the hell of it.
    Aug 2005
    Spring, Texas
    What is Shaners? does anyone know how much hp increase this adds, is it even worth messin with
    Jan 2005
    Humble/Houston TX
    shaners throttle body is a stock throttle body that is boared out, ported, polished and has the bump stop grinded down so the blade can open all the way. heres a pic
    Purdy. He did the air tubes the same way I do mine, copper tubing. I don't polish so pretty though. I think the bump/ridge was to help get the air tumbling in the intake. There are enough turns and curves before the valves that I don't think it was necessary. Some people cut the front side of the rod off to help flow but I am afraid it would lead to a twisted butterfly. "twisted butterfly" sounds like some kind of new-age rock band.
    Apr 2005
    Saint John, MO
    I have a Shaner S3 port job on my elec controlled TB. Purdy, oh yes. Does it actually give a noticable performance gain? Specifically for my 4.8L NA application, not really. Not a very good $$/Power ratio probably. More of an expensive "mod list item" in my case.
    Base: 2004 Victory Red Silverado 1500 2WD RCLB, LR4, 4L60E, 3.73, HD Suspension, P245/75R16 Tires
    Mechanical/Performance: Nelson 93 Octane Tune (See Slamma's CarDomain.Com Page for more details)
    Apr 2005
    Saint John, MO
    Originally posted by RedHeartbeat@Sep 7 2005, 07:05 PM
    ... "twisted butterfly" sounds like some kind of new-age rock band.
    Yeah man i've heard of 'Twisted Butterfly', they rock! I think it was put together by some former members of Twisted Sister and Iron Butterfly.
    Then again i'm a little at times.
