Results 1 to 10 of 16
Thread: Drag radial or full slick netting fastest ET
    Ponca City
    Question Drag radial or full slick netting fastest ET
    A buddy and I have been making a few passes at the track with his ex cab and ran into an interesting debate. We used my drag radials last year a few times and where very consistant 13.92-14.03 pass after pass. This year he is using a full slick that he had purchased and we netted 14.01-14.19. The only changes made where since last year he had 3.73s. This year 4.10s. The 60fts are extemely close but we lost mph and ET. We both expected it to pick up ET, not slow down. So begs my question.... Do you think the softer tire is eating hp? We will be back to the track soon with the dr's from last year and the new slicks.
    Slowest in Oklahoma...
    Sep 2006
    THE 405
    A drag radial will always be faster if you can make it hook and stay hooked
    Jan 2012
    DFW, TEXAS
    gears! that was ur only change right? unless the engine/trans are worn out
    Sep 2011
    Quote Originally Posted by blacstar View Post
    No.... Gears and tires were changed.
    99 rcsb silverado...... boosted.
    Ponca City
    Correct. Only changes where 3.73 to 4.10s. And radials at 28.5 to full slick 29 tall. Oh and about 3500 miles since its a DD.
    Pittsburgh, PA
    A slick typically grows an inch to inch and half. So you'll lose gearing and mph as well. A drag radial stays the same and has better rolling abilities... netting better mph
    Chances are you're way to soft on psi in slicks as well. I run my hooisers at 18 and hook well anything less and 60s suffer
    Jan 2012
    DFW, TEXAS
    Quote Originally Posted by ecld_07 View Post
    that's what I meant, tire height is also part of the gear change.
    Jan 2005
    Humble/Houston TX
    if you can hook a drag radial consistantly, run it.
    old mod list: H/C/I/N/E/G 408
    Ponca City
    Gonna go back tomorrow night assuming weather is good on a radial and see what it does
    what was DA for both times out? can't get a solid comparison without that.
    my experience has the radials as being faster, but the slicks as more repeatable, and easier to recover in the event of wheel spin.
    for manual transmission combos, throw all that out...bias ply only for max performance.
    2000 ECSB Silverado 2wd 5.3/4l60e. basically stock
    1990 Camaro 5.3/t56...not as stock
    1971 Chevelle ls6 cammed 5.3/700r4 turbo build.
