Since the motor in my truck is questionable at the moment. Has had metal shavings on drain plug magnet last three oil changes. More every time I change the oil. I have decided to build an Iron Block LS1. Most of the parts are here and I decided to start a build thread. Looking at 11:1 CR with 8.8DCR and a quench distance of 0.030. I know that is on the limit of pump gas but I would like to run e85 once it is available in my area.
5.3 Block Bored To Fit Stock LS1 Pistons
Ported Oil Galleys In Back Of Block and Oil Pan
Stock Crank Cut .010 On Rods And Mains Due To Lifter Failure In Donor Motor
ARP Rod Bolts
Clevite Bearings
Recondition Stock LS1 Rods
New Gm Stock LS1 Pistons
Ported (By Me) Stock 706 Heads
Comp Cams 219/227 .607/.614 Installed 6°Retarded To Keep DCR In Range
Comp Cams New Revised 918's
LS7 Lifters
Comp Cams 7.4 Pushrods
Melling Oil Pump High Volume Thinking Standard Pressure Spring Come With Both Springs
42# Delphi Injectors
Stock Ported Intake and Throttle Body
Keeping My EBay Headers
Running Trailblazer Stall For Now
I am also going to rebuild my transmission while I have my current motor out for the swap. Let me know what you all think of the parts and what power it will make.
