Results 1 to 10 of 11
Thread: I think I broke it
    Mar 2005
    Eagle Pass
    I am not sure If my truck came with a Limited slip diff or a locker, It Has a towing package, thats all I know, It Shredds both the Rear tires just fine.. Got a little Carried away last weekend and cut donuts for about 15 minutes last weekend , Now When I make a sharp turn, My whole truck shudders and I can hear the tires fighting the turn, I dont think It is Releasing, feels like I am driving around with a spool.. She's Running Just Fine, except Turns feel...off...., Any thoughts, What does it cost to replace?
    Jan 2005
    Humble/Houston TX
    DOH! cant treat the G80 rear end that way! its kinda touchy(aka pos)...mine did that a few times but it never took that long to unlock. the things that i found to work was to take a sharp slow right turn. if that dosent work try stopping on a long straight road and stomping it from 0 to about 80 (treat it like a 1/4 pass). that worked once too. if that dosent work i dont know what to tell ya besides find a good shop and dont put another g80 in. good luck
    old mod list: H/C/I/N/E/G 408
    Feb 2004
    Western, KY
    i love my auburn, it like tires and pavement also
    Mods:
    Maybe STOCK
    "My lugnuts require more torque than your ricer is ever going to produce"
    Sleep: That Stuff Is Overrated
    "You don't care what it is, or who makes it, as long as they race it. You my friend are a true Gear Head!" (Drew Anderson)
    Who's the real culprit of Obeisity: video games because their scared of physical activities, or Pillsbury for being so delicious?
    Dec 2004
    Benton Arkansas
    my best freinds 04 Z71 did that and he took it back to the dealer because it was supposed to be limitedslip. they replaced the govener assembly and now its fixed.
    Daily driver: '97 Z-71 reg. cab, electric fans, dual bats, K&N cold air, custom built muffler, and your standard blue light special equip...
    My Baby: '67 GMC swb small back glass. 388ci stroker, old school bowtie heads est. 450hp, scat steele crank, eagle H beam rods, and Keith Black pistons, but only pushing 10:1 compression, fed by an Edelbrock 750 carb. THM350 trans. shiftkit w/manual valve body, 2800 stall going out back to some highway 3.42 gears, tubbed.
    Auburns ROCK!!!!
    Jun 2003
    i a running an eaton and love it. way better reaction from it from the g80. day ad nigh.
    04 supercrew 5.4 3 valve-magnaflow catback
    formerly 02denali 12.79@107
    Mar 2005
    Eagle Pass
    um, Whats A Good (Cheap) Locking Diff I can Get For my truck, I have driven it another week and tried everthing, It is Still Stuck, Its like I have a Frikin Spool! Need a Replacement Very Soon, seing as I drive it over 1,200miles a weekend( almost want to say its eating more gas allong with the rear Tires&#33, Any Suggestions....?
    Mar 2005
    My 04, did that about a mnth ago, and i took it to the dealer, mine started like that kinda locking when i would turn, my buddies would tel that it was locked, the about a week later, it was making a horrible noise. I had to lift it to stock and took it to the dealer ship, by the time i got there 10 minute drive my truck had thrown all the oil from differential, and round cover in the diff was broken and the gearrs where broken, it ended up the whole differetial was messed up so they had to replace, it had only 4,000 miles, right now its working great. And no more donuts.
    Chrismans/California GearAuburns are inexpensive. Mine has been working great for about 8 years now. I bought it from Chrismans/California Gear. They were very reasonable.
    Mar 2005
    Eagle Pass
    Okay, From reading this crap here http://www.traction.eaton.com/prod2.htm
    What I understand is The Flyweight Govenor Thingy Is Stuck/toasted, Can I whack it or take it out and Clean it like a Govenor In a Transmission? or just order it, does anybody know The Damned Part # and where I can order it? Will My Diff Explode into A Thousand peices If I keep Driving It Stuck Like This ? Oil Smells Well Done
