Results 1 to 10 of 11
Thread: oil tube stuck in my block??
    Oct 2009
    huntington indiana
    i recently put gibson headers on my avalanche and couldnt get the oil tube out. so like a jack ass i broke the mounting tab off, thats where booze comes into play. me and a friend got the headers on and he took off while i finished up. I got the bright idea to weld the mounting tab back on, so i pulled the dip stick out and set it on the intake so i wouldnt weld it in the tube and saw something shiney and got distracted. i got back to the truck and put the dip stick back in the tube and started welding, when i got done i realized i welded the dipstick in the tube (feel free to point and laugh)! I went to the chevorlet dealer and got a new one and started to replace it and I CANT GET THE OLD TUBE OUT.... any help or ideas would be great, i would really like to check my oil.
    Maui, HI
    Im sorry let me take a moment to...
    Um maybe heat it with a torch n whack it or pliers it out? Please take a pic this is just too interested.
    99 Silverado 1500 4x4 RC 4.8
    4L60E, 3.73, Homemade CAI, 92oct Quik tuned,
    08 Tahoe radiator/fans, Dumped exhaust... summed up one loud pig caller |[226K! on odometer|
    You may have to remove the oil pan to push it out from the bottom side, inside the engine.
    Oct 2009
    huntington indiana
    i have tried everything but heat, i really dont want to take the pan off. my problem is that the tubes are not very strong and if f around much more its gonna break and the pan is gonna have to come off, was just wondering if their was a trick to get the bas***rd out
    Buffalo or Rochester, New York
    I ran into kinda the same problem with my truck when I was putting in my long tubes. Instead of breaking off the bracket I cut the dipstick tube with a big pair of side cutters. Now when I started doing an oil change I need the dipstick again. All the guys I know at the local Chevy dealer thought the dipstick tube was just a press in deal but it isn't. I believe the factory epoxied them in when they assembled the engines. There is a very hard orange ring around the top of my dipstick tube right before it goes into the block. I have tried everything to get the tube out but it wont budge. My truck is currently in my barn with the oil pan coming off later today because the tube just wont move. While I have mine apart I'm putting in an oil cooler.
    Thats some crazy welding skill getting the dipstick to weld to the tube without burning through one or the other!
    Kyle - 2004 K1500 Z71 RCSB 5.3
    - Nelson 93 Octane Tune - LPP Long Tubes + Y - Gibson Extreme Duals - Cut Up Stock Air Box - 10.95 @ 67 in the 1/8 -
    - '05 Pickup Front Brakes - '05 Suburban Rear Brakes - Russel Stainless Braided Hoses -
    - DTRL's Turned to Park Lights - 4-HI Mod - '05 SS Seats -
    - I downshift near hybrids so they can hear me hurting the environment. -
    Oct 2009
    huntington indiana
    not welding skill but lack of, and i was so proud of my welding job and even painted it and it looked so good then i realized i welded the dipstick in. from the factory they tack weld the tab and when i broke it off it left 3 little holes in the tube that caused my problems.
    Nov 2009
    chicago, il
    Try to pry back and forth with pliers on the tube to walk it out of the hole. If that doesn't work, take the pan off and it's hammer time on the tube from inside.
    GET OUT OF HERE WITH THAT RICER MATH!
    If you aren't living on the edge, you're taking up too much space.
    Oct 2009
    huntington indiana
    i was hoping that their was a easy way to do it, my left hand is trashed and turning a wrench inst a possibility for a few more weeks. oh well, maby if i ask the tube nicely it will change its self
    Nov 2009
    chicago, il
    Quote Originally Posted by st8kfinger View Post
    Use your right hand...
    when this happened to me i just wiggle it back and forth alot and pulled the hell outta it and it broke loose but usually i get the attitude if it dont come out get a bigger hammer, if it breaks or bends yea that sucks but at least its out
