Results 1 to 10 of 12
Thread: Vss
    Feb 2009
    Vss
    Hi all,
    i swap a 2003 ,6.0,LQ4 with a Th 700R4 behind in my Jeep CJ-7, it is a Vehicle Speed Sensor necessary to run the Engine ?
    Thanks in Advance
    Hardy
    Absolutely, its a must-have item to make the engine run properly.
    Feb 2009
    Ok.
    Will this VSS work
    Painless Wiring 60116 - Painless Performance Speed Sensors
    And where conect the VSS ? I have no cable in my exist harness...?
    Direct in the ECM port ?
    Here's a post with some wiring diagrams.. http://www.ls1truck.com/forums/lsx-t...-diagrams.html
    You really need a 40 pulse per revolution output. Dakota Digital sells some output modules.
    Jun 2007
    tulsa, oklahoma
    i just put a 5.3 4l60 into my 90 yj, had to use an adpt from V8 conversion manuals, parts for V8 S10, Datzun Z, Jaguar, Chevy TPI & TBI, Colorado, Astro Van V8, Volvo 200 & 700 the have the adpt that goes between the trany and the transfercase, also sell the sensor that you need, it works really well, and very easy install. the sensor screws into the adpt. there number is 1-925-462-3619 if you call them they can explain to you what you need and what they have, they were very helpfull to me,
    1987 jeep wrangler, 1999 LS 1, 4l60 231j transfercase, dana 30 frontend ford 8.8 rearend 3:73 gear ratio. sandersons shortie headers, 2.25 inch exhaust into 3 inch flowmaster muffler.
    The multiplier from dakota digital won't work. I went in there and talked to them and they said that the most you could get up to was like 36. I got the one from jags that run because they are the only company that I found that makes this work which is unfortunate because they suck to work with. Couldn't you just tune your computer to think that it is running a manual trans? I am probably way wrong however. ha
    Feb 2009
    My TH700R4 is not computer controlled why i need a VSS...?
    Or i need a PCM tune for manual Trans ?
    Racoon Twp., PA
    Vss for shift points, or the tranny will mechanicaly shift=clunk. PLus other sensors see things moving but not your speed so the engine will stall out. My wrangler did that when the mechanical speed sensor wasn't in all the way
    It is on the transfer case right? So no, you can't tune it out.
    2013 CC 5.3
    81 C10 LS1 project
    Oct 2007
    Manchester, NH
    Quote Originally Posted by hardy350 View Post
    Hi all,
    Thanks in Advance
    Hardy
    No you do not. A VSS has nothing to do with engine operation.
    -Derek
    www.GiffinsPerformance.com
    1989 GMC Sierra
    5.3 Swap, Z06 Cam, Z06 Valve Springs, NX Express 150 shot, Giffin Performance Custom Front mount turbo kit, MPT70 Turbo, HP Tuners, Meth Injection, 4L80E with transbrake, 3" exhaust, 3.08 gears
    Turbo Build Video
    It will run fine with exception of major shift issues and the MAP/MAF/VSS tables being screwed up.
